NO! If you connect both breathers together you are essentially blocking the crankcase ventilation system. Major oil leaks, from places you never thought could leak.
If you have a PCV valve, run the hose from the front breather to it. If you don't have the valve, plumb it to a catch can.
"A" series engines like all the breathing ability they can get. I run extras on all of the race engines.
Jeff
