Brosky
This is a topic that is sure to bring a lot of comments, so here goes.....
I was talking to Bob, the machinist doing my engine the other day and I asked him what he would use for break in and then normal driving oil after the first 600-1,000 miles. Though I'm not surprised at the first part of his answer, I am at the second.
He said that he would run the initial start-up and 20 minute run with Shell Rotella T 15W-40, which is high grade diesel oil. He uses it in all of the high horsepower engines that he builds and breaks in on his dyno. Then a drain and filter change and another run of of the same oil for 600 - 1,000 miles at which another change takes place.
He said that if I saw that I wasn't burning any oil at that time, I should switch to a full Synthetic oil, such as Quaker State's Q-Torque Power SM rated synthetic oil.
Bob said that he felt very comfortable with these oils and the new cam installations that he does. As I looked around, I saw 10-12 boxes from Comp & Crane cams for engines waiting to be built.
Oil is a topic that has been discussed a lot in the past, but it has been a while, so I'm looking for break-in as well as after usage thoughts or experiences, if there are any on this.
