Brake wrench
Guinn
Had to tweak the rear brakes on my 78 B as I had NO parking brake! Couldn't find my $12 Moss wrench and didn't want to chance damaging the adjuster, so made do quite nicely with a 7/16th allen wrench seated in a 1/4" drive 7/16th socket!The 1/4" end slips over the adjuster perfectly.
Just passing this along in case any other dope loses his (or her) brake wrench.
Guinn
Neat tip! I never gave that one a thought.
I take a 1/4 " drive socket that the other end will fit over my 3/8 drive ratchet and adjust with that.
Bob
I've always just used a 1/4" open-end wrench for adjusting my rear brakes; works just fine.
Bet you didn't have a semi-frozen adjuster, Mark! I really needed the long reach of the brake wrench the first time. I was afraid I might round over the square doo-dad with na open end. Would probably work OK now that it is freer. Thanks.
Guinn
Does everyone adjust them with the wheels on or off? I usually get both wheels off the ground on jack stands and take the wheels off.
Bob
"Does everyone adjust them with the wheels on or off?"
I found it easier to reach the LH adjuster with the wheel off as the exhaust gets in the way otherwise, so take both wheels off so I get the same feel on each side.
Guinn
i just jack the side of the car up until the back wheel is off the ground (with the stock jack). Then adjust and repeat for the other side.
