PatGalvin
Good evening:
Am cleaning up the brake and clutch MC reservoir on the TR3A. Have a couple questions for the esteemed brain trust.
First, the reservoir has fittings on the bottom that attach to the hard tubes that carry fluid to the MCs. These fittings are sealed with rubber O-rings or seals. Does anyone know where I can obtain these rubber seals?
Second, the reservoir has a tall tube in it to separate the clutch from the brake. I inadvertently cut the brake and clutch lines before I noted if this tube was on the brake line or the clutch line. Does anyone know?
Finally, I'd like to purchase new springs for the brake and clutch forks. Does anyone know where this can be purchased (Moss sells as an assembly).
Thanks very much.
Pat
Thanks very much.
Pat
