davester
I'm rebuilding all of the brakes on my '71 MGBGT and one issue I have is that the clevis pin on the master cylinder is horribly worn, plus the pin hole in the push rod is really elongated. The push rod appears to be unavailable. The clevis pins I've found have all been aluminum, so I'm concerned that they are not of sufficient strength for this application.
I have three thoughts on this:
1. Perhaps have washers welded to the sides of the pushrod and get a longer clevis pin to fit (though I'm not sure where to find a steel one). I'm a little leery of this idea because if the welding doesn't work well, then I will have ruined my no-longer-available push rod.
2. Drill out the pushrod and brake pedal and fit a larger clevis pin.
3. Just replace the clevis pin and not worry about the hole elongation, play, and aluminum.
Has anybody here dealt with this issue successfully? Are there steel clevis pins available? Are the aluminum ones sufficiently strong?
