I decided to fit new rear brakeshoes on my 100/6 BN4.
At the same time I had the front and rear drums balanced.
Now that it's all together and adjusted according to the manual, two problems have arisen:
1) The brake pedal goes nearly to the floor. On pumping it two to three times resistance is felt but after about 5 seconds the pressure is gone again (the car does brake but I'm not too keen on risking anything) I found no hydraulic leaks;
2) I am able to pull the handbrake cable all the way up
I definitely need help. /bcforum/images/%%GRAEMLIN_URL%%/confused.gif
Hi Guest!
