My Mk2 Midget has developed a brake problem . The fronts seemed to stick on yesterday for some reason .The master cylinder is the tandem type with both brake & clutch master together. This has been stripped and re sealed . There are new copper pipes throughout and areoquip flex pipes . One calliper is new , the other was good and reused when the brake work was done earlier this year.
It was as if they progressively came on of thier own accord . I had to remove the pads and drive the pistons back into the calliper and replace the pads at the roadside to enable me to get home . I limped the car home with precious little use of the footbrake . Been out to the garage tonight and even after standing on the pedal they go on and release as they should.
Stripped the M/C cap and the vent hole is clear.
I didnt have time to take the car out this evening so dont know if the fault will return . Gut feeling is that it will .
Any advice is welcome.
