Hi Dale, The right rear short line from the union to the brake cylinder on my BJ7 is copper. I must say that this is the first copper line that i have experience with because I don't think they are legal in Pa. My inspection mechanic hasn't caught it in about 5 yrs now. OOPs, did I say that.
But I needed a brake line just a little while back and ordered one, it is for the other side, which is longer, anyway, I recieved a copper one that i didn't realize I was getting. I didn't use it because it feels so soft. Maybe it is just my mental block because we don't find copper in Pa. I think the original steel replacement lines are the best because they generally last about 40 years anyway. Also, they are strong enough to not get abrasion or impact damage from debre off the road. Here is another aspect to mull over, On the Corvette it is common to replace disc brake calipers with stainless steel sleeved calipers. I have had them on my Vette for about 20 years now. They do solve an enheirant problem with the vette brakes. But, the concept of SS is over applied in the Market Place because everybody is given the impression that SS is the absolute toughest, longest lasting material to use. So, the aftermarket has also developed SS bleeder valves for the vette calipers. I have found from experience that they don't work so well and can potentially damage an otherwise good caliper. What happens is that the stainless steel bleeder valve is so hard that is has no 'crush' characteristic when turned down into the bleeder seat. I have found that they tend to weep. Causing the brake system to gradually get air. Then when you try to make them tighter and turn them down into the seat, you score the seat because the bleeder nipple is tougher than the seat. Eventually you have scored the seat so bad that it will never seal. So you have to be careful why and where you use stainless steel. Another example of using a non-standard alloy, was when I had all my hydralic cylinders sleeved with brass. the likes of master, slave, caliper, wheel cylinders, etc. I had one master cylinder that just would not bleed up. Took it off (3) times, sent it back to the remanufacter each time, got it back, reinstalled it, and no bleed. I finally called another supplier of another standard remanufactured master cylinder, And in discussion mentioned the trouble I was having with the brass sleeved one, He said, why go thru that, the factory type units will probably out live me.
