TR4
Is there an adjustment I can make to the brake pedal on my TR4 so they engage sooner? I just changed the rear rubber hose, bled the system 3 times to ensure all the air was removed and my brake pedal travels much farther before engaging than before I changed the hose. They also don't seem to grab as hard as before either. Is there an adjustment to get the pedal to engage the brakes sooner? I did check the adjustment on the rear pads and those are properly set. Maybe a stainless flex hose would give better resistance than the rubber hose I installed? All advice is appreciated.
