TR5/TR250 Brake Pedal return spring
angelfj1
Just removed the pedal box from the TR250 to replace the bushings. I noticed there is a return spring for the clutch pedal but NOT one for the brake. Can't remember if there ever was one. Should there be, or does the brake pedal depend on the spring inside the servo for return.
Thanks
The SPC seems to indicate that there is only one spring for the clutch. The illustration shows two, but the listing has only one.
