Andrew_Grannis
Hi,
I havnt been on the forum for a long time. If you all remember my Healey was starting up but dying soon after. We finally found that it was a fuel starvation issue. Two things had gone wrong. The SU fuel pump we had rebuilt wasnt pumping like it should have, and the tank we sealed, got sealed too well. We put pressurized air in through the fuel send coming out of the tank and air went into the tank, but the sealent must have covered the hole just enough for it not to work. So, we bought a universal pump and a new tank and it runs like a charm. As a matter of fact, yesterday, after about two months of sitting through the Cleveland winter, we went out and it started right up. The next project is the brakes. The brake pedal does not budge. After looking things over and getting a few opinions about it, weve decided that the rubber gasket (I'm going to call it that) on the push rod of the cylinder must be fused to the cylinder not allowing it to move. So I guess I have two questions. One guy that has helped us along the way has told us that he has had to do this many times and he has just heated it so the rubber melts allowing him to pull the master cylinder off even though he is heating aluminum. We are planning on using this method but I am just curious of other methods that may work. We have also heard a method of using a grease gun with other fittings to get the thing free. My second question is, just so I am sure, which master cylinder is the one for the brakes, as I dont want to mess with the clutch master cylinder. Thanks, Andrew
Hi Guest!
------------- what he said!!!
