I'm in the process of rebuilding the brake and clutch hydraulics on my '67 Healey 3000. The BJ8's all had servo assist, as I understand it, and the earlier cars had servo as an option. The brake m.c. for non-servo cars is shorter, and is in fact the same as the clutch m.c. for all 3000's. To make a long story short, I ordered a new brake m.c. from Moss, and they sent the wrong part twice (same as the clutch m.c., too short), although stock numbers appeared to be correct. Victoria British sent me a brake m.c. which is closer to the correct size of the installed part, but the inlet and exit lines do not match up, and since the lines are too short would require installing and bending new lines. It seems to me that I out to be able to buy a replacement part which is an exact fit. Does anyone have any suggestions for other sources of supply which they have found to be reliable and knowledgeable ?
Hi Guest!
