Well, upon disassembly two years ago, I just didn't take quite enough pictures or notes. So now as I install new brake lines, a bit of confusion reighs. I'm pretty sure that the pipe from the servo (nearest the can) goes rather directly to the stop light switch union. It makes further sense that the pipe from the outermost end of the servo cylinder goes to the four way union. The other three connections there go to the two front brakes and the rear brakes. That leaves the pipe from the master cylinder going to the brake light switch union. My photos cover the rear brakes pretty well. So am I right in general about the routing? The more complicated question is the exact route these pipes take relative to the chassis, especially the front crossmember. By the way, I did save most of the old pipes for reference, but some were just too butchered to save for anything. Thanks in advance.
