Brake line & fitting info needed for '59 BE
Bruce_B
Does anyone know what size brake line (diameter) the BE uses and what size the fittings are at the end?
I need to order some, know that it's Whitworth what not sure specifically what to order.
Thanks.
Get the whole kit from Moss. Then you have it all.
Thanks.
Bruce. The lines are all 3/16" The fittings are all 3/8-24 with bubble or single flare.
PeterC
This is what I did. They're not pre-bet, but they are all the proper size and have the fittings on them. I've replaced one line so far, and it went smoothly.
I only need one line to go from the Brake MC to the Rear Brakes.
Peter - is it the same fitting whether the line is double or single flare?
I thought everything on a BE is double flare.
Thanks
On a stock bugeye the rear brake line runs from the junction on the inner wing to the bracket for the rear flex hose. The junction takes a bubble flare with the proper long shoulder 3/8-24 fitting. I was thinking the rear fitting to the flex line required a double flare, but that may be dependent on the nut? Better ask someone that truly knows.
