Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Silicon Brake Fluid may affect the pressure sensitive brake switch and require more effort to activate the brake lights until it gradually fails.
I've read that "buffering" the switch with DOT 3 (adding a drop in the pressure cup) before installing into a brake system using SBF may help. But how well this works in practice is questionable.
I converted my Healey to a mechanical Brake Switch after having to replace the old pressure brake switch three times. Now the brake lights activate instantly at even a hint of brake pedal and no failures to report. Check your options and good luck. GONZO.
I have heard numerous complaints about the replacement hydraulic switches not working very well. Several people have gone to a mechanical switch. It's likely that a NOS switch would be ok if you could find the genuine thing. The original switch on my BN2 is still fine after 49 years.
I bled the the brakes it seemed to make a differance but not alot. I may still have the old switch that came with the car I will give that a try.Does any one have any info on the mechanical switch
