To test if the brake light problem was in the switch or in the lamps, I jumped the 2 wires going to the pressure switch (leads connecting the 2 screws on the switch). I figured that if the brake lights went on, then the problem was in the switch somehow. Once jumped, the brake lights came on. I'm figuring now that I need to replace the pressure switch? Can they be removed and cleaned, or is it just better to replace them?
