BabaKahawa
I am unable to get my rear brake lights to work. First one side went out then the other.
The driving lights works. I have tested the brake contacts in the socket and they do not light up. How can I test the brake sensor in the engine compartment to see if it works? The supply tank by the wheel well was about half full so I filled the outer portion of the tank. there is also an inter cylinder in the supply tank, it that like a front and rear brake fluid reservoir within the supply tank?
Any suggestions would be appreciated.
