Alan_Myers
Hi all,
What type of grease would you use in the brake drums, where the shoes ride on the backing plate? The manuals suggest "white zinc grease". But, I have no idea what that is! I have some 3M Brake Lube, which I think is called "copper slip" in the UK. It does contain some zinc. (It's handy as an "anti-sieze" on threads. I use on spark plugs in steel/iron heads, etc.)
Any other points in the brake assembly you would grease? Pivot points of the handbrake lever, other places where the shoes rub against adjuster, etc.?
Thanks!
Alan
Thanks!
Alan
