Very good post.... The dot "3" "4" "5" number is the indicator in percentage as to how much moisture the brake fluid can absorb before it is saturated beyond safe operating limit.... 3 percent isn't much by volume, either... so 2 years is max. Another point that is EXTREMELY important! NEVER EVER EVER put silicon brake fluid in an ABS unit! IT WILL CAUSE BRAKE SYSTEM FAILURE! All brake systems get moisture in them, espacially here in Houston, by God, Texas where it is sub-tropical and humid as all get out!!! This includes systems with silicon fluid... I never put silicon in a system because of this... and I'll tell you why. Silicon fluid does not absorb moisture, and moisture is going to get into the system just because it is vented at the cap! Since the fluid doesn't absorb moisture, and the specific gravity of water is higher than that of all brake fluid.... take SWAG (silly wild-ass guess) as to where moisture winds up in a silicon system! YUP! The calipers and wheel cylinders (lowest points). I just last year did a complete restorative brake job on a show(concours winner) 1968 TR250 that had been given the silicon treatment some 2-3 years before. The calipers were so frozen that it took a torch to heat them in order to get the pistons out. The wheel cylinders were just as bad, too. and I got pure water out of both calipers and wheel cylinders upon disassembly that proves my point about where water goes! I converted his car back to DOT 3 and admonished him to flush every 2 years.
