Bret
Ok I admit it - I’m confused.
Brake fluid specifications:
Haynes says – Hydraulic fluid to SAE J1703, yada, yada, yada.
Bentley says – Lockheed Universal brake fluid (series 329S) or Castrol Girling Brake Fluid: Alternatively use brake fluid conforming to DOT-3. Blah, Blah, Blah…
While:
Moss & Victoria British catalogs lists three different types:
Lockheed(DOT-4), Castrol(DOT-4) and Silicone(DOT-5).
Sense, I have now way of knowing for sure what I actually have in my 78B’s master cylinder, I am just going to assume that I will have to flush the system. The question is what type of fluid should I go with?
I just want to be able to go a round the corner to pick-up brake fluid without getting a headache every time.
I’m thinking of going with an over the counter DOT-4? What do you guys think?
FYI – the brakes are fine & just doing a break job and decided to replace the standard brake lines with stainless.
[ 01-23-2004: Message edited by: Bret ]</p>
While:
Hi Guest!
