General Tech Brake Fluid
KVH
Just trying to recall: Synthetic can be mixed with non-synthetic, and Dot 3 is preferred for TR4s but can be mixed with Dot 4? Right?
My original can of DOT 5 said just add it and bleed until purple squirts out. Many years, no problems, but you probably should take John's advice.
Bob
From Valvoline:
Brake fluids can be mixed only if the fluid that you add to the system belongs to a higher grade.
For example, a braking system that has a brake fluid DOT 3 specification can use a DOT 4 or a DOT 5.1 fluid. Also, a system with a DOT 4 can be topped up with a DOT 5.1 without bleeding the system.
However, never top up a DOT 4 system with a DOT 3 brake fluid. DOT 3 won’t be able to meet the temperature requirements because of its lower dry and wet boiling points.
Once again, do not mix DOT 5 with any other type of brake fluid because of its silicone-based composition.
