I was just finishing up my brake rebuild (yes, I know has been quite a while, but until I pick up my leaf springs, schedule is a moot point) when I found that both banjo bolts (left / right front calipers) had small leaks.
I had cleaned (but not sanded) the caliper mating surface and the surfaces of the banjo bolt. I used all new copper washers. I further tightened the banjo bolt after noticing the leaks - I am now at 40 ft-lbs torque on one, and am afraid to go further. Does anyone know what the torque dpec should be?
At this point, does anyone have anything to suggest? I hesitate tearing it all back down as the brakes have been bled.
The car is a 1976 1500 Midget.
Thanks,
Bob Shaw
Thanks,
Bob Shaw
