Jim_Gruber
Bugsy is running low on Brake Fluid and clutch needs a little added as well. Tried two local shops and no Castrol LMA to be found. Castrol Site says it is compatible with Dot 3 or Dot 4. So which is it a DOT 3 or Dot 4 Brake Fluid? I bought some Prestone Synthetic Dot 4. Will this work ok with the Castrol LMA that is in there now?
I believe so but before I add just wanted a sanity check from the list. Thanks.
