Finally got the chance to start on Harry's check list today, and didn't get far before I noticed some obvious trouble. To start with, the clutch reservoir is completely empty of fluid, and the brake reservoir had only about half an inch. I haven't had any trouble at all from the clutch, and as I said, the brakes only started acting funny within about the last 50 miles or so. The car has 10,000 miles since restoration, and with the rusted on filler cap, I'm guessing the reservoir hasn't been open since then.
No sign of leakage around either master cylinder, nor the brake lines to the two front wheels. The clutch line is another story, however. Lots of fluid spray on the lower engine block above the front of the clutch slave cylinder, and an obvious puddle on the floor under the rear of the slave cylinder, so this may be the main (hopefully only) culprit. Are there any likely problems here before I get it up on blocks and dig into this? Seals likely to go, or maybe slave cylinder problems? Would I be wise to have some parts on hand or just wait and see what I find? Why didn't I get any indication from the clutch with a completely dry reservoir? Is there a connection between the brake and clutch reservoir at the bottom, or are they completely separate?
Incidentally, this is the separate brake and clutch cylinder installation, not the early combined type if that makes any difference.
Thanks again for all the help.
Fred
