George Zeck
I am having modest success so far in bringing my "project" back to life. I took the (2) front calipers off the car and replaced the brake hoses (lines looked fine) and compressed the pistons (l & r for each side). Bled ONLY the front's (assuming that I don't need to bleed the back brakes because I didn't touch them). Topped off master cylinder. Braking "power" was LOUSY !! Probably worse than before I started messing with them
Don't see any leakage (only < 10 min after test run). So I think I have everything tight enough. Is there any special way I need to position the "hollow bolt" connecting the brake hose to the caliper ? I just put it on and tighted it firmly.
Should I bleed the back as well or are my calipers shot (they sure seemed fine and not frozen / rusted together)?
Lousy brakes or not -- the car sure turned heads during my two laps around the block !! /ubbthreads/images/graemlins/patriot.gif
