TR2/3/3A Bonnet safety hook
Frank Canale
Bonnet latch broken – Version 2.jpg Snowed in today and more to come so took a shot at drawing on a picture. John, hope you still have power, sounds like Texas got a lot also. The little paddle area is broken off so I could use a measurement from the mounting bracket to the end of the paddle area and the thickness of the paddle area. No rush on this as I can't get out to get any material to make this but it is on the radar to tackle when the mood strikes me. Thank you for all the help, Frank
Frank,
I applaud your wanting to repair this part. Both TR3s I have owned came with this broken. The part now cost about $45. WOW. I will try to remember to go out and measure it this am.
Jerry
1 7/8 long for the whole piece. 5/8 wide. Reinforced as much as possible as this seems to be broken on most cars in our club.
Thank you Jerry. That confirms my thoughts that this part could use a little improvement. I will post pictures once I get started on it. Frank
Moss Motors does sell the hook by itself (without the bracket or rod) for under $23, plus shipping etc. Part #802-276 "Safety Hook". I got one about a year ago and fitted it to an original bracket - worked well.
Thank you Graham for the pictures. I feel like I can beef up the sides where they all seem to break. I think I am going to use a block of 6061 aluminum for the first attempt as it will be easier for me to work with. Looks like I am going to be snowed in for a few days. Single digits at night so the ice and snow isn't going to melt til the weekend. Frank
Hello Frank
What machine are you using to mill out your catch or you just going to cut it away with a carbide burr?
David
I wish I had a mill, but I don't so this will be a little challenging. I think I will be roughing it out with an aluminum blade on a chop saw then to the drill press , burrs then files. I will adjust the plan of attack as I get into it. Strange as it may seem I have always had to make parts with the tools that I have and not always the best or fastest but it helps to keep the brain working. Sometimes you have to figure out a different way to do a task. Frank
I think it'll be plenty strong if you just eliminate that dumb hole they put in it!?! I have a mill, and that shape would be difficult to mill...more of a cast shape. Casting metal is on my bucket list, but I have no experience yet. Still looking forward to another unique solution you always come up with, Frank!
Thank you John, I saw a demonstration of sand casting at the metal museum in Memphis. I also would like to take the class as it could be useful. Still a lot of snow here but nothing like Texas. Hope you all can catch a break soon.
bonnet safty latch bracket damage.jpg This was no surprise as I could tell that the PO had done a repair to this bracket and it did not take much for it to fall apart.
bonnet safty catch bracket repair.jpg There are many ways to repair this but I chose to remake the entire tab as this will be better than it was originally. The new repair tab is slightly thicker (maybe .010") than the parent metal. The tab is made before the original is cut off. I marked the hole then clamped a piece with a hole in it on top so that the hole in the repair would be exactly where it is supposed to be.
bonnet cafty catch damage removed.jpg Here the tab has been carefully removed with a cut off wheel. This way the repair tab is already sized to sit on top of the part that is removed and this also gives you a reference to line up the edge.
bonnet safty catch bracket ready to weld.jpg Here the bracket and repair tab are lined up ready to be welded. It is worth the time to clamp pieces that you are going to weld so that you can get in a comfortable position to do the welding. It takes a little more time but the end result is so much better. The new repair tab has the bottom edge beveled at a 45 degree angle almost to a sharp edge. This bevel allowed me to basically melt the parent metal to the repair tab for almost 100% penetration. I then easily added a little filler metal along the top edge of the joint. To finish that edge only took a minute with a file and was just like it was formed originally. I did flip the bracket over and weld the other side to make sure that there was complete penetration. I don't think this one will break.
bonnet safty catch bracket repair tab welded.jpg The repair has been welded and all that is left to do is radius the top corner to match an original. I don't have an original but it looks like the pictures I have found and I am sure it is close enough.
bonnet safty catch bracket repaired.jpg Here is the finished bracket. This was a fun little project. When I can get out to get some material to work on the safety catch I will bring you along for that part. Frank
