tontonene
Member
I recently removed the transmission on my BN2 to replace the front seal and gaskets, due to excessive leakage. After re-install, I now cannot shift out of third gear. The only thing that was done to the unit after it was pulled was the removal of the bell housing to replace the input seal and new gasket. The clutch, pressure plate and release bearing were also replaced. Third was the gear the unit was left in when removed. It appears the internal shifting linkage is stuck. The transmission operated fine prior to removal. The car sat all winter with the transmission drained of fluid. I have removed the side plate to inspect. Everything looks clean and nothing loose. Any ideas on how to regain the shifting ability would be much appreciated.
I really do not want to pull the transmission out again if I don't have to. This was quite a "one man job".
thanks,
Kip
thanks,
Kip
