bighealeysource
Hey all,
Since it was 72 degrees here yesterday had my 100M out for a drive ( I know rub it in for those already snowed in ). Have a problem with the gear shift lever actually getting stuck between gears when I go to shift into reverse. This happens occasionally and only when shifting from a forward gear into reverse. If it does occur, like the trans is stuck between gears as if I let out the clutch, can hear a noise like a turning gear but not a gear grinding. It will then pop back out of this no mans land after trying to move the gear lever around but strangely enough, not immediately. Trans works great otherwise and just replaced the brass bushing at the end of the gear lever thinking that might have had something to do with this problem. Could this be the selector shaft for reverse or any other ideas ? Trust me, I can live with this versus taking the trans out but mainly wanting to figure out what it might be and will it damage other parts or just remain an occasional problem.
Many thanks,
Mike
Many thanks,
Mike
