mbrooks
I investigated the heater hose hook up today prior to opening up the water flow round the heater for the first time. I noticed a few things I could do with some help on.
1. The heater valve that comes off the middle of the block on the right hand side has the take off pointing forward instead of back. It has been connected to the heater inlet with a piece of 5/8ths hose [which incidentally is chafing on the steel wire on the oil filler]. Since the valve does not have any kind of union on it to enable it to be pointed in a chosen direction, why does it point the wrong way?
2. The other connection to the heater which should be via a hose/copper pipe along by the manifold/hose has the copper pipe missing and has been connected with a long length of 5/8th hose all the way. The proper short hoses are listed as unobtainable. If I get the proper copper pipe, will 5/8th hose, which fits the heater stubs and the valve ends fine, be the correct ID for the copper pipe?
Thanks in advance
Mike
Thanks in advance
Mike
