Bruce Bowker
Just got back from a week of "playing" with my cars. A bit too cold in NJ for me but....
1956 BN2 with a problem.
tI ran perfect but the last day I tried to start it and it would turn over nicely but not fire. I tried again and same thing. It sounded like I was not getting any spark. I turned off the key and turned the key back on and the entire system was dead. It was a if the battery had suddenly been disconnected.
Battery is fine.
I checked the ignition switch and I am getting continuity across the two terminals when switched on and none when off.
Last year I made a mistake when putting a fuse back in (nothing to do with the current problem). This was the lower of the two fuses. I placed it a half notch too high and when I got in the car all gauges were registering and the fuel pump running. I tried the key but nothing stopped. I thought the ignition switch was bad. Spent awhile checking it and suddenly thought to check the fuse again and saw what I had done.
SOOOO by doing the same thing this time with etye fuse wrong, I could start the car and everything works. It just does not work when the fuse is in the correct place. The system is entirely dead.
Again battery is fine, fuses are both fine, switch is good. Is there a relay?
Thanks
Bruce
Battery is fine.
Thanks
Bruce
