Not sure if I have asked this here yet, but my OD (in a '74) does not usually disengage properly. I bought it with no history, cleaned it up, checked the screen, etc and put it in ~ 2yrs ago. I now have it out and need an idea of where to go with it.
My first impulse is to remove it from the trans and just go through it, but are there things I should look at before I disturb anything? I'm quite sure it is not an electrical issue, it can usually be taken out of OD by a quick on/off the throttle after the switch is turned off. It always engages fine. The first few times I used it it did not do this, it crept in after several months of use.
Thanks for any input...
