I had decided the last time I posted to try and get the car back on the road for one more summer before doing a re build. I thought that I did not torque the head correctly the first time I replaced the head gasket so I bought another head gasket and decided to try again as compression was good and the leak seemed to be coming from under the manifold area and no coolant in the pistons or in the oil. I checked the head with a straight edge and it looked OK.................so I installed the 2nd head gasket. Motor ran for a minute OK then billowing clouds of white steam. I'm assuming the head is warped. (Yah I know I should have taken it to a machine shop to get the head flattened). So I pulled the head again and this time there was coolant in the cylinders and some near the lifters (saw that the lifters are worn and need replacing). The odd thing is the new oil I had put in still looks good on the dipstick and there is no chocolate milk there? Drained the coolant and only a little less than a gallon came out so the rest of the coolant must have steamed off? So I am thinking of taking the head to the machine shop to see if it is still repairable and see if i need new valves and replace the guides and lifters. Question is have I done irreparable damage to the rest of the motor? I have replaced basically all the mechanical parts on the TR3 over a 20 year period but have never taken the engine apart besides head removal. Any advice on where to go from here?
