Hi,
I am looking for a lesson on 'blow-by'. To the best of my sketchy knowledge now it seems to be from either leaky valves seals or piston rings not doing their thing well. Is there any way I can test rings to see if they are causing the blow-by? I have had the head rebuilt recently and if those are actually my two most likely suspects
I am more inclined to the ring theory. This is going to be a pretty lame way of describing the amount of blow-by but you can see a steady stream of smoke coming out of the breather pipe when under the car at idle.
After a run you cannot avoid seeing and smelling smoke wafting up from the oil filler/breather cap.
Is there a way to determine how much is 'normal' or, as I have read elsewhere, is any amount of smoke abnormal? The car runs really well, at least I think it does ...not having another tr3 or LBC to compare it to.
The next question is, if any amount of 'blow-by' smoke is abnormal, is there any way to do any sort of test to see what is causing the smoke? For example if I used some very thick oil, or simulated the use of the same, would I be able to be confident that my problem is actually bad rings. Whether I have bad rings or not are there any other avenues for me to follow other than an engine out full blown rebuild?
Thanks very much,
Jim Lee
1959 TR3A
TS50500L
Thanks very much,
Jim Lee
1959 TR3A
TS50500L
