Block heater valve
alexm
Can anyone tell me which way is On/Off on the little heater valve on the side of the engine on my 3000? Is it on with the handle in-line with the hose, or is it Off with the handle at a right angle to the hose? Thanks!
Handle at a right angle to the hose. Actually, if you clean it up on the out side rim at about that same position you will see "OFF" inscribed in the housing. Be careful if you try to move it the handle is very easily broken off.--Fwiw---Keoke
