Hi Jim,
I bled mine over the summer, after having replaced the slave cylinder and the clutch master cylinder, the hose, push rod and dust cap.
Assuming everything in your case is in good shape and you only need to bleed, the method I was able to use was nothing more than a plastic tubing connected at one end, in this case, the bleed screw at the slave, and the other end of the tubing going all the way down into a glass jar on the floor (or lower than the discharging point from the slave cylinder) so that as you are pumping the pedal and the fluid is filling in the jar, there is no chance of air syphonage back into the tubing and subsequently, back into the clutch fluid line.
This method allows you to do it yourself.
It would help as did in my case to have the center hump removed so you can witness any bubbles still passing through the clear tubing. Also, loosen the bleed screw just enough to open at the slave to prevent air seepage back at the nipple. I remember once someone here mentioning the use of a rubber "O" ring around the bleed nipple, but I didn't do that and was still able to get away with an air tight seal. The "O" ring idea is an option to think about, though.
Also, as you do the pumping of the pedal, always make sure you have fluid topped off in your master [tank].
As I now recall, it really would be a good idea to have the hump removed because I was able to tighten the bleed nipple as I was pressing down on the clutch pedal. That assured no air seeping back at the nipple. A bit of dexterity required but not impossible. Have your correct tools handy.
That's one solution to bleeding the clutch.
Paul
