Went to the movies with my bugeye last week, but had problems getting it into gear on the way home. Turns out the slave cylinder was leaking badly. I replaced it,and bled it. I was all set to go for a drive tonight with my sweetie, but found that unless I pump the clutch pedal before I shift a couple times, I can't get it into gear easily. I have bled that stupid slave cylinder twice now. Did I just do a bad bleed job, or is it something else? Any advice would greatly be appreciated.
Kevin
Kevin
