Trevor Triumph
On the 66 Spitfire I replaced rubber parts in the master cylinder and wheel cylinders. Using the MityVac to bleed the system, worked on the rear cylinders. The front right caliper produced lots of air bubbles but no fluid. When I connected the Vac to the bleed nipple on the left caliper, the vac showed suction but when I turned the screw nothing happened- no fluid, no bubbles. When I nearly took the bleed nipple out, without the hose attached, some fluid ran out. I wanted to drive the car this weekend. Hmmm... T.T.
Hi Guest!
