bleed clutch?
No trick required, should be really easy. Don't forget to adjust the clutch linkage. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
With my TR4, I bled the system 4 times because each time I ended up with having to pump the clutch pedal to get it to work so I then took the slave cylinder out of the bracket and let it hang down in order to get all the air out on the 4th bleeding. That worked great for me. This procedure was recommended on another post.
Phil
