RobertTheFrogOwner
Ok,
I've been lurkin' for quite some time now. And learnt a lot. But not everything, so here's my question:
I own a frog(bug)eye (FYI it has 2 S.U. H1 carbs) Occasionally, when the engine is warm I get some black smoke from the exhaust. I tried adjusting the carbs and for a while that worked. But then the front carb started leaking gas and I replaced the gaskets on both carbs (and those gaskets needed to be replaced) I noticed that the jet on both carbs now goes 'all the way up into the carb' whereas this did not happen before I replaced the gaskets. After re-adjusting the carbs I still get the occasional black smoke. What can be the reason for getting black smoke from the exhaust (other than too rich mixture because of wrong adjustment of the carbs)? Any help would be appreciated (as the s.o. is asking why we can't go for a ride
