Hi Gang:
I am posting this to help anyone who has decided to refinish their BJ8 wood dash.
I did considerable research on this topic here on the forum and elsewhere, but the important task of scraping or chipping the original shellac finish is a tough job and makes the veneer vulnerable to blade slip damaged. I goofer a couple times
I found a better way!
With a small heat source such as a butane lighter ( I used a BBQ lighter a propane torch is too hot) apply from a distance the flame's heat to the finish in a small 1 inch areas. Moving often, bring the heat closer until the shellac surface turns opaque. I tried a heat gun but the surface heated waas too broad.
The surface will then "pop" and peel away from the veneer safely. For resistant pieces of finish, while hot, gently slide a flat zazor blade under the peeling surface which will now easily seperate from the veneer. Should take 2 hours total.
Thats my tip from learning the hard way.
Andrew, Toronto /ubbthreads/images/graemlins/laugh.gif /ubbthreads/images/graemlins/canpatriot.GIF
