Hello, Healeyophiles! Again, I come on a quest for your knowledge! I started the long-put-off replacement of my original trunk lining and found a problem or two. No surprise there as nothing goes easily on a Healey project. However, these are small problems/questions that I am sure someone can answer. Therefore, rather than do my normal plow ahead and "just do it" I am going to do the smart thing and "ask directions".
First: I purchased 3M trim installation aerosol. There were two choices - the "clear" for light and medium weight work with vinyl, etc. that had "adequate support" and the "yellow" industrial strength for vinyl roof installation, headliner repair, etc. It seemed to me that the "clear" lightweight to medium weight was the right choice so that is what I bought. However, upon removal of the old liner I notice that the original adhesive is definitely yellow in color and the stuff is really, really glued on tight to the point that I have to scrape off the old jute backing in most places. So, should I go get the yellow 3M industrial strength adhesive? And, do I have to remove all of the old adhesive before putting on the new material or just spray over it?
Second question: The wooden support bar for the battery is essentially rotten. I cannot figure out how to remove it from the inside fender panel as the connective devices appear to be threaded onto a stud. However, they are imbedded into the wood.... So, here is my problem: What is the best way to remove this wooden support so I can replace it with a good piece of wood?
Thank you very much in advance. Now I am gonna sit here and sip on a nice "cold one" while anticipating all the great advice that is gonna just pour right in!!!!
Thanks, guys! Stever
