<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Larry Campbell:
Dave,
Any thing that I should look for in terms of wear or problem areas that may be present beyond the cleaning, or anything that I might be further ahead in doing since I will have it off the car anyway?
<hr></blockquote>
I can't think of much else. The big spring on the end just absorbs the rebound when the flywheel speed exceeds the pinion speed & kicks the pinion back out of engagement. There is a very light spring on the other end also, neither of which really have any problems. I think the light spring is just to prevent accidental dragging of the pinion teeth of the ring gear when the car goes over bumps or hard braking.
Some wear on the pinion gear itself is also normal. No problem unless the pinion is obviously chipped or worn a lot.
You can test the pinion action by clamping a starter mount flange firmly in a solid vise & apply power to the starter. when the starter turns the pinion should snap into the engaged position & return when the power is removed & the starter stops. It may not return perfectly but it doesn't matter much because in actual operation the flywheel will force it as mentioned above.
you probably don't need to go further. You could go through the whole starter motor, new brushes, bearings, & what all, but it is probably not necessary if it is otherwise working well.
Good luck,
