AUSMHLY
The rear trim rail gets screwed to the drainage channel.
There is a rubber strip that goes between the two pieces. The rubber strip is curved on top. It seem to mirror the inside of the trim rail.
It would seem then that the trim rail presses down against the top of the drainage channel, or is the rubber pressed against the sides of the trim rail and drainage channel.
When I line up the screw holes in the trim rail with the holes in the drainage channel, the trim rail top does not press against the top of the drainage channel. It's about 1/4" away from each other.
I maybe putting the carriage in front of the horse.
The top material is attached to the trim rail with 36 clips. Where are the clips attached to the trim rail? Does anyone have some photos showing where the clips are pressed on?
Thank you,
Roger
Thank you,
Roger
