BJ8 passenger foot well [LHD], right wall
Jerry
The panels for the right wall, passenger side , foot well, has a large hole in it. I have been told that you put vinyl on the wall and then the hole gives more room for your feet. This was if the car was RHD? And it gave you more room for the gas pedal?
Anyway, how far off the wall is the panal mounted? Since this is now the passenger foot well, do you use it for map storage or what? Any other suggestions?
Jerry
late BJ8
Jerry,
As far as I know (Moss videos) it is mounted flush with the wall with two sheet metal screws on the front section top and bottom and the rear is secured to the flange with vinyl wrapped aroung the weather seal flange and glued. Have a good day!
John
