Larry Campbell
Member
After occassional bouts with the ignition lite staying on, it finally wouldn't go off at any RPM. The LBC shop who performed some of the more complicated repairs on the suspension for me checked the generator, said all ok, replaced the Volt regulator, no go, still not charging when I picked it up Friday. Now they say it needs a new generator. By chance, I stopped by a parts house Sat. to see if they had a set of brushes, none available, but they had a Lucas generator #22900 which indicates is should be the correct part for my 67.
Swapped out, polorized as per the instructions,(still don't know what that means), now the ignition lite stays off, getting around 12.65V's at idle, about 14.75V's in the 2500 or higher RPM range.
Here's my question:
Everything seems to be ok, no smoke, nothing fried, everything works, my question is, did I get lucky ($100 for the rebuilt generator, judging by the dust on the box I think they we happy to sell it at all) or are there other things I should be checking or aware of. I am working off all the advice from you experts out there that says lucky and Lucas are never used in the same sentence.
Here's my question:
