Daniel Kaminsky
My gauge needle flops around so never know just what fuel I have. Have run out of gas twice. Help!
Dan
'67 BJ8
Dan
'67 BJ8
Dan
'67 BJ8
When I removed (over a year ago) the old fuel tank float, I disassemble it to show the "guts" to the BJ8 owner. The coil had stretched and had gaps which caused the fuel gauge reading to be inaccurate. The dual brush float is stronger and more durable. The old one will wear out, which is usually the case in all of the above threads. The BJ8 owner has had no problems with the accuracy of his fuel gauge readings.
Most modern gauges use a bimetallic strip for the gauge which reacts slowly to changes in measurement. The Healey gauge uses a moving coil galvanometer type gauge which reacts quickly..... Most modern systems, I believe, have a combined sender and pump, and the float moves vertically and doesn't have the leverage our old-school floats have on the sender coil.
Volkswagen and Porsche use a "vibrator" in series to the fuel gauge to slow down the reaction time at the gauge.
https://www.jbugs.com/product/113957099A.html
Vehicles with Smiths voltage stabilizers can easily be identified. If the fuel gauge needle “jumps” off the empty position when the ignition is switched on, the vehicle is NOT equipped with a voltage stabilizer. Fast responding gas gauges are based on the “balance magnet” principle and do not require the voltage stabilizer. If, however, the fuel or temperature gauges slowly drift up when the ignition is switched on, the car uses a voltage stabilizer and gauges based on bimetallic heating elements. The voltage stabilizer can be mounted any number of places. Consult your service manual to determine its location
