Wanted BJ8 FlyWheel
Robbie S
Hi My Friends, I am looking for a flywheel and ring gear that will fit the 6 CYL BJ8 engine, I can find a ring gear however no flywheels seem to be available new or used. Any help finding one would be appreciated.
Warmest Regards,
Robbie
I may have what your looking for Robbie .
I have two Tri Carb engines that I made one good one out of . So I have a spare flywheel and ring gear do you need 8 or 12 bolt mount ?
Let me know if you still need one .
Luke Skywalker in Canada. I am looking for a good used late model BJ8 flywheel Part No 22B136 . 4 Bolt flywheel with 3 dowel pins (early BJ8's had two pins). Am also in Canada. Chris
I have a four bolt 2 pin with ring gear and also have the clutch diaphram assembly to fit it if that is any use to you ?
If you are still looking for the flywheel, I recently purchased one from the Toy Shop in San Diego and he had it blanchard ground for me.
Paid $275
also David Nock at BCS said he has them, it was going to be $175 plus shipping and then I would have to have it machined.
I went with the Toy Shop because he was going north towards my area to go vintage racing and we met close to my house. Saved me the shipping cost and believe me the blanchard grind job was perfect.
Nick
Luke Skywalker in Canada Further to my post looking for a used BJ8 flywheel, I found a rare used one for Cdn 300 (about US $220) at piecesanglaises, a parts company in Laval Quebec. Chris
