Hi JJS,
I gotta chime in here and say that enlarging the manifold for HD8s is much easier than you may think. The bolts are in the same position so all you have to do is open up the hole. Spray some marking blue on the manifold face and set a 2" gasket on and scribe the inside of the gasket, then grind/sand out to the line. If you screw it up, don't worry because the 1 3/4" manifolds are cheap on ebay. This way you can retain all your stock throttle linkages - if you change manifolds, you will have to have BJ7/BJ8 throttle linkages and IMHO that's a lot more work than opening up the manifold...(oh and don't forget you have to enlarge the holes in the heat shield too)
Dave Phillips
