Hello everyone, I'm still in the cutting and removing phase of my Healey reconstruction. Don't have alot to add to tell you yet about my progress. But I did buy two new steel rear fenders. I must say that I have never had such poor fitting fenders to start with. It is going to take alot to make these fit this car... anyway, about the wiring harness. I have, I believe, a unique situation with the wiring for my BJ7. You see the lighing and ignition configuration on my car is the later European BJ7 set up where I have separate running and turn indicator lights on the front similar to a BJ8 except my lights are the smaller glass lucas lens. Also my ignition is mounted with a steering column lock, under the steering column. Well, guess what, I can't find a wiring harness, configured with this arrangement. I can get a standard US export BJ7 harness, but it has the hook-up for dual filament bulbs up front and I assume the ignition switch in the dash. I beleive my only option is to buy the standard harness and then modify it to fit my car. Does any one have any other ideas.
Thanks, Dave C.
Thanks, Dave C.
Hi Guest!
