bob hughes
Hi Guys
Woke up the other day to do some welding in the garage and when I pushed the BJ7 out there was a not so nice puddle of hydraulic oil waiting for me under the near side front wheel. I had only recently replaced a corroded brake line from the rubber to the caliper, but the connections were dry, the disc (rotor) and the caliper were covered in Hydraulic oil so I have to suspect the caliper. The parts are on their way, and I have discovered the BJ8 caliper rebuild here, is there any other advice, ideas etc. on how to get the piston in with that darned dust cover configuration?
I am intending to split the caliper and the internal transfer seal has been purchased, so this should make life a little easier.
Bob
Bob
